Discussion topic: Mini box
Message posted on 10 Jun 2025 06:49 PM
Mini box
My mini box light stays on red. It will not turn to green, I have tried every way of doing this, how do I get a new mini box
Message posted on 10 Jun 2025 07:27 PM
Re: Mini box
Hi @Five
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this Work through the following link
https://www.sky.com/help/articles/sky-q-box-wont-turn-on.
This also refers to minis
