Discussion topic: Mini box
This message was authored by Sonny1981 This message was authored by: Sonny1981
Mini box
I've just switched to another internet service provider from Sky but still keeping my tv package through Sky but I have 2 mini boxes in different rooms and non are now working
any help appreciated
Re: Mini box
Hi @Sonny1981
Reboot the mini as above.  Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
Sonny1981
Re: Mini box
Done all this,
on my main sky q box no apps are available and says I don't have subscription for boxes when I do
Re: Mini box
@Sonny1981 wrote:
Done all this,
Hi @Sonny1981
Sonny1981
Re: Mini box
No that hasn't worked either, will have to call sky tomorrow
thankyou though 👍
