Discussion topic: Mini box
This message was authored by: Jade+bonnie+stapl
Mini box
Sky mini box keeps freezing and you have already been out twice to sort it and it's happening again
Re: Mini box
@Jade+bonnie+stapl wrote:
...and you have already been out twice
We're other customers here, so we haven't.
Without any other detail you'll need to call Sky again.
Re: Mini box
Hi @Jade+bonnie+stapl
Reboot the mini as above.
Re: Mini box
@Jade+bonnie+stapl
Where one or more boosters haven't resolved the issue, Sky might consider installing ethernet cable (with your permission).
if you don't want that then it's your choice whether to cancel Multiscreen and return the Mini box, or sort out your own solution (such as Powerline adapters)
