Discussion topic: Mini box wont connect to q box
This message was authored by: Veryuseful
Message posted on 11 Jan 2026 01:59 PM
There has been a technical fault for a few days - try this
On ur q box
Go to settings
On ur q box
Go to settings
Go to set up
Go to preferences
Then make sure standby mode is on ACTIVE
This will make sure ur q box gets updates and then try and connect ur mini box - do ur network first, then connect to q box.
This might take 5 minutes or a couple of
hours but it worked.
Good luck
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 11 Jan 2026 02:14 PM
Re: Mini box wont connect to q box
@Veryuseful even with the stanby mode set to none or any other setting the box still receives updates
