Discussion topic: Mini box won’t work
Message posted on 23 May 2025 09:16 PM
Mini box won’t work
Mini box has an amber light on it but won't go green and open sky
Message posted on 23 May 2025 09:30 PM
Re: Mini box won’t work
Hi @Cathymbd
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
