Discussion topic: Mini box won’t work
Message posted on 04 Sep 2024 01:45 PM
Mini box won’t work
Sky multi room box won't connect to main sky q box have followed instructions on tv still doesn't work but we had a power cut in our area
Message posted on 04 Sep 2024 01:50 PM
Re: Mini box won’t work
Hi @Stacie5 .
Reboot the mini as above.
