Discussion topic: Mini box won’t connect to Sky q
This message was authored by: Brackendog
My sky q box and mini box have been unplugged from the mains for 3 months due to house renovations. The main box is working but asking to insert the card chip up . I have taken it out and rubbed it and still same message. My mini box is coming up Error code MR104. I have followed all instruction but still not connecting to sky q box. Any help appreciated .
This message was authored by: bemak187
Re: Mini box won’t connect to Sky q
@Brackendog  I suspect you will need to contact sky.  I dont know the specific timescale but I suspect if the system is off for an extended period it needs reactivated on Sky's end, specifically the viewing card.
Hi @Brackendog
Regarding the viewing card
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
If you get it working then try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
