2
This discussion topic has been answered Discussion topic: Mini box stops working when main box is turned on
This message was authored by: OG2025
My mini box works fine until someone turns on and tries to watch the main sky q box at the same time. At that point we can only watch recordings on the main box as well.
This wasn't an issue previously. I've tried resetting the broadband and turning all boxes off at the mains but still the issue persists.
does anyone know the issue or how to fix this please?
Re: Mini box stops working when main box is turned on
Hi @OG2025
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Hi @OG2025
Avatar for OG2025
Thanks @oldfella  I've  done that and it looks like it's done the trick. Thanks very much for your help
