Discussion topic: Mini box signal
Message posted on 21 Aug 2024 03:10 PM
Mini box signal
My mini boxes keep losing signal downstairs in my house. Every time I want to watch something, I havE to reset the box
Message posted on 21 Aug 2024 03:39 PM - last edited: 21 Aug 2024 03:39 PM
Re: Mini box signal
Hi @Theresa16
Have you tried completly reconnecting them?
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
