4
This discussion topic has been answered Discussion topic: Mini box says I am not authorised to watch a recording, but I can view it on the main q box
This message was authored by: Malpoet
I record formula 1 races on channel 406. Sky Sports is part of my package. I can play the recording from the main Q box, but when I try to view it on either of my mini boxes it says I am not authorised.
I can watch Channel 406 live OK.
I have tried re-connecting the min boxes by using the reset button. That makes no difference.
This message was authored by: nigea99 Answer
Re: Mini box says I am not authorised to watch a recording, but I can view it on the main q box
do you have UHD - if so 406 will be the UHD channel & minis cannot play UHD recordings
Many of us record both the UHD & HD version so we can watch on either box
Avatar for Malpoet
Thanks. I'll try that. I never had any problem  playing channel 406 recordings on a mini box before Sky changed the router to fibre.
Avatar for Malpoet
Yes, that works. Thank you.  I'm pretty annoyed about he new fibre router. Some of my apps won't work with it and I can't view UHD recordings on my mini boxes when I could on my old router.
hi @Malpoet
SKY Q mnis cannot (& never could) display UHD recordings
