Discussion topic: Mini box problem
Message posted on 15 Jan 2024 10:05 PM
Mini box problem
I have sky q, and 4 mini boxes with multi room. We can use 2 mini boxes at the same time out of the 3 with no problem. However if we turn on the 4th mini box it says maximum boxes in use even though that is the only mini box turned on. All 3 other boxes are on standby. Why is this box different?
Message posted on 15 Jan 2024 10:20 PM - last edited: 15 Jan 2024 10:20 PM
Re: Mini box problem
Hi @Samjax
Try a Reset Settings in the main Q box hidden menu.
