Discussion topic: Mini box not working
This message was authored by: Flowerpot
Message posted on 10 Jan 2026 06:21 PM
My mini box isn't working despite doing all the on screen prompts. My sky Q box is working. Has anyone got a solution apart from covering it with a coat and smacking it with a hammer 😂
Find out more
Message posted on 10 Jan 2026 06:23 PM
Re: Mini box not working
hi @Flowerpot
Have you power down restarted (removed plug / switched off at mains) the main box & waited >30s before restarting ?
Message posted on 14 Jan 2026 03:48 PM
Thank you for your reply.
I ended up pressing the wps button on my router and that sorted the problem.
