Discussion topic: Mini box not working
Message posted on 22 Sep 2024 01:28 PM
My mini box has a solid amber light and the TV shows "No Signal". Nothing works, although my main Sky Q is working
Message posted on 22 Sep 2024 01:31 PM
Re: Mini box not working
@Bealeyboy21
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
Message posted on 22 Sep 2024 01:34 PM
Hi @Bealeyboy21
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
