Discussion topic: Mini box not working
This message was authored by: Alison80
Its stopped coonecting to wifi we gave tried to reset
Re: Mini box not working
Hi @Alison80
Reboot the mini as above.
Avatar for Alison80
Reset page on mini will not go past page 2 pressand hold until it flashes-its already flashing
Hi @Alison80
If you are carrying out a Network reset on the mini then read my previous post.
You do not press the WPS on the mini in a Network reset.
ie
Avatar for Alison80
This has still not worked
Hi @Alison80
please explain exactly what steps you are carrying out and exactly what happens
