Discussion topic: Mini box not working
Message posted on 05 Jun 2024 05:04 PM
I have 2 miniboxes, 1 of them is just a grey crackerly screen, i plugged my other box in to the same wires and it works fine, the box has given up
Message posted on 05 Jun 2024 05:24 PM - last edited: 05 Jun 2024 05:26 PM
Re: Mini box not working
Hi @Danhill
Reboot the mini as above.
Failing all of the above
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
