Discussion topic: Mini box not working. Remote also broken so replaced but cannot set up because mini box not working
This message was authored by: Clare58
Mini box will not come on. Remote broken so have new one but cannot connect it as mini box not working.
Re: Mini box not working. Remote also broken so replaced but cannot set up because mini box not work
Hi @Clare58
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
