Discussion topic: Mini box not responding to remote
Message posted on 31 Mar 2023 06:06 PM
As above!
Message posted on 31 Mar 2023 06:20 PM
Re: Mini box not responding to remote
@Lorsy Try this link for help with your Q remotes
https://www.sky.com/help/diagnostics/sky-q-remotes/what-would-you-like-help-with.
If you get to the end and decide the remote is faulty click tried everything then need more help and or contact us and you get a form to order a replacement one free.
Message posted on 31 Mar 2023 06:23 PM
@Lorsy wrote:
As above!
Hi @Lorsy
First reboot the mini.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front of the mini box (Amber led)
Then
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 22 Jul 2023 02:02 PM
Hi have tried all you say and still not getting any response. Help please.
Message posted on 18 Mar 2024 04:04 PM
I have tried switching the box off and also changed the batteries in the remote but still no joy
