Discussion topic: Mini box not connecting
This message was authored by Mallyhodson This message was authored by: Mallyhodson
Mini box not connecting to the router on settings and network connection it says that it's connected on the Sky Q
This message was authored by MightyQuinn This message was authored by: MightyQuinn
Re: Mini box not connecting
Hi @Mallyhodson   Is Sky your broadband provider?
Hi @Mallyhodson
Reboot the mini as above.
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the mini and you will need to contact Sky directly.Hi @Mallyhodson
Mallyhodson
I have tried all of the above
Have you got a Sky Q booster then @Mallyhodson
Mallyhodson
No I don't have a sky booster I have just received the Sky max router
