Discussion topic: Mini box no satellite connection
Message posted on 05 May 2024 07:45 PM
No satellite signal on mini box
Message posted on 05 May 2024 07:50 PM
Re: Mini box no satellite connection
Hi @Char65
Reboot the mini as above.
