Discussion topic: Mini box keeps disconnecting from Sky Q box
This message was authored by: foxlj227
One of my mini boxes disconnects from the main Sky Q box every time it's off for more than a few minutes.  I have to go through the process of resetting the connection, which it does without any problems, each time I want to use it.  It's in the room directly above the main box so I don't think it's a problem with the signal.  No issues with WiFi.
It's not a big problem but quite frustrating, so any tips to stop it happening would be much appreciated.
Re: Mini box keeps disconnecting from Sky Q box
@foxlj227 when you say when its off for more than a few minutes do you mean when you put it into standby (amber light) or atre you switching it off at the plug ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for foxlj227
Just standby
