Discussion topic: Mini box issues
Message posted on 03 Aug 2024 10:15 AM
Mini box issues
For atleast 2 days one of my mini boxes won't work properly. No apps snd when downloadeding says I need to upgrade my subscription.
I have done rebniting Sky Q box. Rebooting router and refreshing apps on the mini box and waiting 24 hrs.
Also turning the whole system off and powering back up. Still not working.
Message posted on 03 Aug 2024 10:21 AM
Re: Mini box issues
Hi @Ipad..
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
