Discussion topic: Mini box issue
This message was authored by: S+Aley
Mini box issue
Hi, I can't get my mini box working, I have plugged in the hdmi to the to and box and we have power. When I first power up the box I get a red light for a couple of seconds. I have also tried the reset button on the back but then the red light just stays in?
Re: Mini box issue
Hi @S+Aley
Have you tried try pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
