Discussion topic: Mini box is not working Error message MR001
Message posted on 02 Mar 2024 07:07 PM
I have followed all the steps on resetting the mini box but it still isnt working
Message posted on 02 Mar 2024 07:13 PM
Re: Mini box is not working Error message MR001
I have foolowed all the steps suggested but the box is still not working
Hi @Mebs1
Reboot the mini as above.
Message posted on 02 Mar 2024 07:35 PM
