Discussion topic: Mini box doesn’t work
Message posted on 21 Jan 2024 10:52 AM
My sky box downstairs works but the mini box in my bedroom has stopped working all of a sudden after being fine for over a year..
the power lights on but no signal..
Message posted on 21 Jan 2024 11:04 AM - last edited: 21 Jan 2024 11:04 AM
Re: Mini box doesn’t work
hi @Crob1
If the power light is Amber and not green try pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 21 Jan 2024 11:40 AM
The light is green
Message posted on 21 Jan 2024 11:44 AM
My screen is saying no signal
Message posted on 21 Jan 2024 11:51 AM
I've turned it off and on again which seems to be resetting the system- but it keeps taking me to a no signal screen...
Message posted on 21 Jan 2024 11:53 AM
Error MR104
Message posted on 21 Jan 2024 12:10 PM
@Crob1 wrote:
Error MR104
Hi @Crob1
Reboot the mini as above.
If the mini still does not connect and if you can get into the menus try a Network Reset on the mini.
Message posted on 15 May 2024 06:27 PM
The mini box will not pick up the service
Message posted on 27 Apr 2026 10:15 AM
Can you give me the contact number for assistance
Message posted on 27 Apr 2026 10:51 AM
@Roadrunner-0077 wrote:Can you give me the contact number for assistance
Hi @Roadrunner-0077 You have added to a thread that is two years old. If you are looking for help from fellow customers it may be better to start your own. Note, telephone numbers are blocked in this community.
