Discussion topic: Mini Box Freezing and drop outs
This message was authored by: Jinxy999
Hi, I hope someone can help with this issue.
Recently all the mini boxes on my Sky Q system have started playing up.
The most used one freezes constantly and then less frequently will not connect at all.
The Network connection shows as: ' Theres a problem with your network connection' but when you go to setup it always says its OK.
Another mini box always needs starting as though the power had been switched off.
I've done the unplug for 30 decs reset on the Q box and the minis which doesnt help, plus reset the BT router.
My configuration is each mini is plugged into a BT Wi-Fi disc via an ethernet cable apart from one on a Powerline connector. The Powerline connected mini is doing the same thing.
Any help would be greatly appreciated as I've run out of ideas!
Re: Mini Box Freezing and drop outs
Hi @Jinxy999
All Q boxes need to be connected to the same Network by the same method.  So if you are using Ethernet to BT Discs then All Q boxes need to connected by Ethernet to a Disc.
Avatar for Jinxy999
Level 2 icon
Thanks for you replay oldfella but I dont think this is the issue as this configuration has been working fine for years.
They are working off the same network, its just the connection method is different.
Ethernet -> BT WiFi Disk -> Network
Ethernet -> Powerline -> Powerline -> Network
This message was authored by: TheMekon
Hi, I have the same problem with freezes & dropouts. I added powerline adapters to the Sky full fibre modem, Sky Q box, & Mini box, reset Sky Q & mini box - no improvement. The next thing I tried was to turn off the 2.4 WiFi - better but not perfect. Then tried turning off 5 WiFi - same result. But I did notice that now the freezes & dropouts start happening around 9pm, as I don't have anything turning on or off during these times, I'm beginning to wonder if it's interference form surrounding neighbours WiFi?
