Discussion topic: Mini Box Error Code MR102 ?
Message posted on 20 Oct 2025 04:29 PM
Turn on my TV and the Sky showed no signal.? Reset QBox main TV working, reset BBC Hub. Went to Mini Box & TV - No Picture. Went through settings/reset and final screen displaying Reboot Router and showing Error Code: MR102.
I AM DISABLED - do I need an Engineer and New Mini Box ?
Message posted on 20 Oct 2025 04:55 PM
Re: Mini Box Error Code MR102 ?
Hi @Duzzy
MR102 is a connection issue.
After rebooting the router and when it is completely back up and running complete the following.
First try reboot the main Q box again and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 31 Oct 2025 08:18 AM
This error code MR102 has come up every morning I am fed up of having to reset everything every morning when I was offered a sky q mini box I didn't realise I would have to reset it every morning and what's more I don't have time in my day for doing this. Maybe unplugging it and putting it in the bin would be a better option!!!! You can't seem to talk to anyone any more 🥹
