Discussion topic: McBain
Message posted on 13 Jun 2024 07:41 PM
McBain
Hi I have Sky Q 4K and a 4K TV how come I can't watch anything in 4K?
Message posted on 13 Jun 2024 07:47 PM - last edited: 13 Jun 2024 07:53 PM
Re: McBain
Hi @McBain1
See following help link
https://www.sky.com/help/articles/setting-up-ultra-hd
If your TV won't display 4K content, it's possible you're plugging into an incompatible port. Try another one or check the manual on your TV to see which ports you should be using for UHD. Also the TV HDMI input must set for UHD. Normally Deep colour or Enhanced on some TV's
Message posted on 13 Jun 2024 08:06 PM
Re: McBain
Hi @McBain1 Do you have a UHD subscription? What is the hardware version of your Sky Q box?
Message posted on 14 Jun 2024 01:40 PM
Re: McBain
Thank you. I will try this... fingers crossed
