Discussion topic: Maximum mini box limit
This message was authored by: peter+t20
as per the title, i have seen mentioned the limit is with a 2tb q box only 2 minis can be watched at the same time ( ie q box+2 minis so 3 tv's ) but i found the below on the sky website saying 4? is the sky website wrong or have they changed the limits
Concurrent streaming
  • Sky Go and Sky Go Extra customers can stream on two devices at a time.
  • Sky Q Multiscreen and Sky Glass/Sky Stream Whole Home customers can stream on four devices at a time.
Increasing concurrency (Sky Q only)
If your device is connected to Sky Q, it'll assume the concurrent streaming limits for Sky Q, i.e. two. To increase it, disconnect your device from your Sky Q box so that it can use your home WiFi connection: in Sky Go, go to Settings and select Disconnect from Sky Q.
Re: Maximum mini box limit
The bit you have quoted there applies to Sky Go on your devices only and not to a Sky Q mini box.
@peter+t20
In addition to that posted by @caesarome ~
you can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
The original 1TB (non-UHD) Sky Q box only allows one mini to be in use. All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
