Discussion topic: Main sky box staying black
This message was authored by: Julia+Moir
Main sky box not working staying black
Re: Main sky box staying black
Ensure your TV is on the correct input.  Hit the 'Sky' button on the remote too.
Try a reboot of the Q box if necessary.
Hi @Julia+Moir
If your Q box is showing an Amber Led (and not Green) have  you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
If your Q box is already showing a Green Led
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
