Discussion topic: Main sky box freezes
Message posted on 01 Mar 2026 08:21 PM
Main box feezes and blue light circles but mini box works ok.
Message posted on 01 Mar 2026 08:34 PM
Re: Main sky box freezes
Hi @brynithel3
Try a Reset Settings in the main Q box hidden menu.
