Discussion topic: Main box cannot access recordings mini box cannot connect to main box
This message was authored by: Nlebo
The sky help says there's a problem with the main sky q box and when I press resolve it says I don't have sky q I've reset everything turned the boxes off for 5 minutes and the broadband box but still comes up the same
Re: Main box cannot access recordings mini box cannot connect to main box
Hi @Nlebo
Exactly what message are you seeing on the main Q box after rebooting it ?
Avatar for Nlebo
There is no error message on the main sky box but won't record and cannot access recordings.
I'm the mini it says there is a problem with your satellite signal
Looks like it may be a hard drive issue @Nlebo
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
