Discussion topic: Main Sky Q box working, mini boxes not working
This message was authored by: JaseG1
My main Sky Q box is working, mini boxes are not, can't watch anything on them
Re: Main Sky Q box working, mini boxes not working
@JaseG1 Have you tried rebooting your main Q box ie
then
reboot each mini
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @JaseG1
Try a Network Reset on the minis.   Start with the one nearest to the main Q box.
When you carry out the Network reset on the second mini,you can also use the first connected mini for WPS if nearer than the main Q box (or Sky router if on Sky broadband)
This message was authored by: Ck11
My sky mini box is not working so frustrating as this keeps happening while the Sky Q is working perfectly
