2
This discussion topic has been answered Discussion topic: MYSKY_1998
This message was authored by: seren75
MYSKY_1998
I'm trying to install discovery + from the sky shop but I keep getting MYSKY_1998. Is there a cure?
Re: MYSKY_1998
Hi @seren75
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
See following link for Software versions and how to check and update.
https://www.sky.com/help/articles/updating-sky-box-software
Re: MYSKY_1998
Hi @seren75
Avatar for seren75
Re: MYSKY_1998
Thanks. It seems to be working now.
