Discussion topic: MR204 error on minibox
This message was authored by: Graham195
I'm getting above error on mini box, was once a week but getting more frequent. Main box fine and signal good, but mini box stops working. Any ideas?
Re: MR204 error on minibox
Normally a connectivity issue @Graham195
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
This message was authored by: Lennyshef1
I am having the same issue on a regular basis, sometimes the reset works, other times I am in limbo for over an hour. Today has been a nightmare reset 9 times, not connected for over 3 hours! It has been getting worse and worse I have a booster next to my mini and main router and sky Q are within 5 m of mini and each other! Often both connections are ticked but I have error message and no TV
Avatar for Graham195
I got in touch with Sky, they did a few checks and sent me out a new minibox which arrived the next day. This worked fine.
