Discussion topic: MR104
Message posted on 11 Apr 2025 04:34 AM
MR104
Mini box will shutdown to fault page quoting MR104 error I scan box run test no change yet at exactly 6am service on mini box restored all apps Netflix Prime Paramount etc constant freezing or buffering
Message posted on 11 Apr 2025 08:45 AM
Re: MR104
Hi @Guv64 Check that both SKYQ boxes have standby modes set to Active or None as your problem sounds like the main SKYQ box is entering standby mode between 02;20 and 05:45 and is set to ECO mode?
This would stop the Mini box from connecting to the main SKYQ box, and showing the connection error MR104
To change your standby settings:
Press Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, followed by Standby mode and select the setting you want.
