Discussion topic: Lost signal
Message posted on 25 Jun 2024 10:56 PM
Lost signal
Located in LE15 and we lost out satellite signal earlier this evening?
anybody now os any issues?
Message posted on 26 Jun 2024 05:21 AM
Re: Lost signal
It will be a problem with your own set up, not nationally.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 26 Jun 2024 09:09 AM
Re: Lost signal
Thanks , ciecked all out connections seem ok, it's odd as it just dropped out around 8.30 mid way through a recording when we where out.
I guess I will need to arrange a Sky engineer
Message posted on 26 Jun 2024 09:22 AM
Re: Lost signal
@NigelMay wrote:Thanks , ciecked all out connections seem ok, it's odd as it just dropped out around 8.30 mid way through a recording when we where out.
Is it still out? If so, what channel(s) are affected?
Message posted on 26 Jun 2024 09:23 AM
Re: Lost signal
Unfortunately all channels, rebooted box again this morning but it still says no satellite signal
