Discussion topic: Lost UHD
Message posted on 25 Apr 2023 07:04 PM
Lost UHD
Hi
i've lost UHD (both) and 1080p today. All working well for months, no changes by me. Switched on tv and it said your settings have been changed. Can't change in av settings (not accepted). Have switched everything off and back on again as well as checking connections.
LG G2
Sonos Beam (Gen 2)
500mb broadband
Thanks for any help
Message posted on 25 Apr 2023 07:09 PM
Re: Lost UHD
@Nimol wrote:
Hi
LG G2
Sonos Beam (Gen 2)
500mb broadband
Thanks for any help
First thing to try: With the SKY Q box turned on press the following keys in sequence
Home 1 0 8 0 Home
If that gets you access then try setting back to 2160
Should you have problems I suggest a full power down restart of your Tv (i.e. unplug or switchoff at mains)
Message posted on 25 Apr 2023 07:16 PM
Re: Lost UHD
Home 1 0 8 0 Home tells me my settings have been set to default ( now 1080i !)
Still wont apply any setting higher than that.
Everthing powered down and restarted including tv and Sonos
Message posted on 25 Apr 2023 07:23 PM - last edited: 25 Apr 2023 07:24 PM
Re: Lost UHD
hi @Nimol
I am guessing your TV is up to date but I suggest you try updating the TV's firmware
After that double check the TV's setting for Deep color (I think that is the LG option) on the HDMI used for SKY
Message posted on 25 Apr 2023 08:10 PM
Re: Lost UHD
Firmware for tv, sky and beam up to date.
Switched off deep colour and back on again.
Replaced HDMI cable
UHD from tv apps still works
