Discussion topic: Lost Sound on TV Sky Q Mini
Message posted on 24 Apr 2024 10:36 AM
Hi,
As my topic title suggests, I have lost Sound for no reason.
I have went through all the trouble shooting on the forum and I opted to reset the Sky Q Mini box.
However, when it tries to connect to the main Sky Q box downstairs it comes up with a blue screen which states There has been a problem activating your Sky Mini Box and then asks if this is the first time I've seen this error message and there's two options Yes or No, but it looks like my Sky Q remote will not work to pick one of these. All the remote does is volume.
How do I proceed with setting up the mini box again if I cannot pick the yes or no ?
Not sure why all this has happened, as it's been working for years. Once I past this option,and if it does not work, I'm going to use a new hdmi cable. If that doesn't bring my sound back, I'll be into Sky Protect for a new mini box.
Main TV is a LG OLED evo C2 65" 4k". Sky Wifi Booster. Sky Protect. BT Smart Hub 4 Router on Full Fibre 900. Sky customer since 2000.
Message posted on 24 Apr 2024 04:47 PM
Re: Lost Sound on TV Sky Q Mini
I have managed to get my sky Q remote paired and working again, by finding a post on here and pressing 7 and 9 together and the pressing 1 and 3 together, however, I'm back to were I was before, everything works but just no sound at all. I'm going to try another hdmi cable.
Message posted on 24 Apr 2024 05:16 PM
hi @152bobby
Please may I suggest that you try a power down restart of your TV.
Some people have found this can restore sound
Message posted on 24 Apr 2024 05:59 PM
Thanks I also tried that. I have just spent the last hour on the phone with Sky Protect, they were very helpful, but EVERYTHING they suggested, I had already tried. So they are sending out a new Sky Q Mini Box.
Message posted on
27 Apr 2024
09:37 PM
- last edited:
29 Apr 2024
11:11 AM
by
Kelsingra
UPDATE: I had one FINAL attempt and I switch EVERYTHING off and UNPLUGGED everything from the mains power and left it for 2 days (a bit OTT), anyway, once I plugged everything back in, all works as it should.
I could have (removed) not told Sky Protect and got a free Sky Q Mini Box, but that's just not my nature and I have cancelled it and told them that everything is working again.
Thanks for everyone's input and help.
Moderator note: Removed inappropriate language
