Discussion topic: Lost Sky Sports on Multi Room
Message posted on 03 Mar 2024 01:43 PM
I've Lost my Sky Sports Package on my Multi Room which I have not cancelled
Message posted on 03 Mar 2024 01:44 PM
Re: Lost Sky Sports on Multi Room
What are you seeing when you try to view one of the Sports channels? Any error message?
Message posted on 03 Mar 2024 01:46 PM
Asking me to upgrade my subscription
Message posted on 03 Mar 2024 01:59 PM
@IC1956
It might be worth trying a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
