Discussion topic: Losing internet connection
Message posted on 17 Nov 2023 12:23 PM
Message posted on 17 Nov 2023 12:29 PM
Re: Losing internet connection
Hi @Julie912
Assume this is your main Q box?
Have you carried out a Network reset on your Q box exactly as follows:
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
