Discussion topic: Losing TNT1 and TNT2
This message was authored by: Hiffy166
Hi
On HD channels 410,411 and 413 sometimes - TNT1 and TNT2 break up and give 'there is a problem with you satelite signal'. I have checked the alignment of the satelite dish and replaced the LNB but no joy. All the other channels are A1OK. Signal strength and signal quality are both typically 80% sometimes down at 70% - this problem is independent of the signal strength and quality.
Sometimes the regular 868 and 869 channels are OK when the others fail - sometimes not.
Clearly main Q box reset a number of times and cables checked.
Main box has plenty of recording memory left.
Satelite dish is on the side of the house.
Re: Losing TNT1 and TNT2
@Hiffy166
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@Hiffy166 wrote:
Hi
hi @Hiffy166
As you have posted in SKY Q perhaps we should advise  that SKY would replace an LNB & re-align if necessary - is there any specific reason you did it (or got someone to) ?
Was the dish & LNB checked with a wideband capable meter or if not what ?
You should be aware that SKY Q satellite info does not report the channel being watched but a fixed transponder set in an engineer's menu
Avatar for Hiffy166
Hi Daniel
Many thanks for your help – it’s really difficult - I have 2 devices to help me find the satellites (and a compass) - they are both screaming at me or full deflection for the alignment I have - suggesting I have the best signal I can get. I only get the message for these channels.
We have tried micro adjustments, but it makes no difference - it is only slightly different to the adjustment by the Sky engineer - using that position it is worse!
Checked out your link - we have checked all that stuff. The killer is that it is only the TNT channels 412 the Sky channel is fine!
My next step - change the box ES340D9 which looks like Sky Q just in case it is not behaving.
Thanks again.
Avatar for Hiffy166
Thanks -  I have changed the LNB and the alignment has been checked.
Made many adjustments  using satellite finders - still only trouble on TNT HD channels.
Lets hope changing the Sky Q box fixes it!
@Hiffy166
Sky will no doubt want to send an engineer to check and/or adjust the dish before dispatching a replacement box.
