Discussion topic: Loose cable outside
Message posted on 24 Feb 2025 02:01 PM
Loose cable outside
Our satellite dish is on the back of the house, with a cable running over the roof to the front. The cable is no longer secure, due to the recent high winds, and hanging down low at the front of the house. How can I get this secured, before it gets worse, and can a Sky engineer do this? I haven't been able to contact anyone in Sky for help. Thanks
Message posted on 24 Feb 2025 02:07 PM
Re: Loose cable outside
Sky no longer provide engineer support for Sky+ equipment (where you've posted) so you would need to engage a local satellite engineer to repair it for you at your own expense. Or now might be a good time to consider upgrading to Sky Q, as your dish and cabling will be checked at no additional cost to you as part of the Skq Q installation.
Message posted on 24 Feb 2025 02:08 PM
Sky no longer provide engineer support for Sky+ boxes (where you've posted) unless you have Sky Protect. You would either need to egage a local satellite engineer, or if the cable is undamaged, a handyman to secure it for you.
Message posted on 24 Feb 2025 02:20 PM
Loose cable outside
Message posted on 24 Feb 2025 02:28 PM
You have posted the same in the Sky+ board so which do you have… Sky+ or sky Q?
Message posted on 24 Feb 2025 02:30 PM
See my reply on your duplicate thread on the Sky Q board.
Message posted on 24 Feb 2025 02:33 PM
Sky Q
Message posted on 24 Feb 2025 02:36 PM
Then give Sky a call to arrange an engineer.
Message posted on 24 Feb 2025 02:40 PM
@Daniel0210 wrote:Then give Sky a call to arrange an engineer.
Or employ a local independent which is probably quicker (the dish & associated cables belong to you, unlike the boxes which are only loaned to you)
Message posted on 24 Feb 2025 02:42 PM
You could go down the independent company route as suggested but that would be at your own expense but have to agree it may be quicker.,
Message posted on 13 Jun 2025 08:55 PM
Hi there, the cable at the back of the house seems to be loose, it's hanging low, I'm worried, thanks
Message posted on 13 Jun 2025 08:57 PM
Can you help please
Message posted on 13 Jun 2025 09:12 PM
@Hollydolly wrote:
Can you help please
@Hollydolly Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other. You will need to call Sky You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
