Discussion topic: List connection
This message was authored by: Jeannnnnnnie
List connection
Disconnected my satellite wires and now they won't connect again
Re: List connection
It can be that removing the cables you may have bent the centre copper wires.
Check the cables and try inserting them again.
Avatar for Jeannnnnnnie
Re: List connection
Yes I did think that. And reconnected them a few times. Lining them up and swapping them over.  They might he damaged I'm thinking now. Thank you
Re: List connection
hi @Jeannnnnnnie
Do you have your own dish or do you have a commnal feed ?
