Discussion topic: Linking a second device to Netflix
This message was authored by: EMcD
Hi,
I would like to link a second device to Netflix through my Sky package but Netflix wants me to set up account and pay. Anyone know the stepsI should follow.
many thanks
Re: Linking a second device to Netflix
@EMcD If you are trying to watch on a second device all you should need to do is open netflix on the device then log in with your username and password you set up when you originally set it up on your Sky Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for EMcD
Thank you Laing 1,
That's what I have been trying to do but have had no luck so far. Nevermind, it's not a necessity in life.
Thank you for being so prompt.
@EMcD wrote:
Thank you Laing 1,
hi @EMcD
As @Laing1 says you can login to any other device with the same credentials - the limit is active sessions.
This would suggest you are not using the correct credentials
you can check which email you used, assuming you are signed in on your SKY Q box:
In the app:
Up arrow to select the Top Row actions
Tab left to your profile icon & Select it
Arrow down to Get Help
Next to the first entry  (Member) you should see Account Email & the email address used
Avatar for EMcD
Thanks Nigea99,
I'll give it a go and see if it helps jog the system.
