Discussion topic: LG TV HDR
Message posted on 02 Jul 2025 12:48 PM
LG TV HDR
Hi Folks,
Just a quick one, im a long term sky customer with Sky q so i find this forum great,
My Question isnt actually sky related but i know how fantastic you all are, i have purchased a 32 lg tv for the bedroom,
so using the native apps on the tv only, i get hdr for netflix as i have the premium package , i also get hdr for Apple tv app , i dont get it for Amazon or TNT via the discovery app, i also get the HLG HDR screen pop up when watching hdr tests on youtube app,
i know i cant get any hdr through the minibox,
i get all the native apps through my oled tv downstairs as well in hdr so i know its not my account deatils for those apps,
Once again thank you.
Message posted on 02 Jul 2025 01:00 PM - last edited: 02 Jul 2025 01:01 PM
Re: LG TV HDR
@Tom+Shinkwin wrote:
Hi Folks,
I may be misreading your post but I am not too sure what you are asking - however :
Although HDR (High Dynamic Range) is separate to 4K, many providers do not provide content in HDR without it being 4K/UHD
Your TV may be HDR capable but as far as know there aren't any 4K 32" TVs
Message posted on 02 Jul 2025 01:03 PM
Re: LG TV HDR
Thanks for reply,
its just i can watch it on my 32 tv and it comes up the hdr pop up in the top right corner for netflix and apple tv app, so i thought it would for tnt sports through the d+ app, and amazon.
Message posted on 02 Jul 2025 01:12 PM
Re: LG TV HDR
Thanks for reply,
Sky Q content will only be in HDR (when available) for UHD content.
As minis are not UHD capable you will not get HDR through a mini.
Message posted on 02 Jul 2025 01:16 PM
Re: LG TV HDR
Thanks for reply, i know i wont via Sky , this is for the native tv apps only.
Message posted on 02 Jul 2025 01:19 PM - last edited: 02 Jul 2025 01:20 PM
Re: LG TV HDR
As I mentioned many providers do not supply HDR on non UHD content - as you found Prime is one, I am fairly confident Disney doesn't either
edit BBC iplayer being another
Message posted on 02 Jul 2025 01:24 PM
Re: LG TV HDR
Thank you, that makes sense
Message posted on 02 Jul 2025 09:52 PM
Re: LG TV HDR
TNT have very little sport in HDR. The next programmes I can see on their TNT Sports Ultimate channel are the Wimbledon finals on 12th and 13th July. Virtually all they show in UHD and HDR is football and rugby.
However there is the odd replay of a match - go on the left menu to sport then across the top to football and then go down the rows. You will find a replay of the Champions League final labelled UHD. It is something over five hours from memory. There are two versions, make sure you select the UHD version. If you can get HDR from the app that will work.
