Discussion topic: Keep getting missing listings on Sky Q
This message was authored by: JAMESPHILLIPSuk
 I keep resetting the box and then a few weeks later it happens again, also any app like netflix or YouTube plays for about a few mins then cuts back to the main screen. Any ideas
Re: Keep getting missing listings on Sky Q
Hi @JAMESPHILLIPSuk
Avatar for JAMESPHILLIPSuk
Yer i have to do what you said every few months and then it goes again
