2
This discussion topic has been answered Discussion topic: Keep getting message about entering our sky viewing card
This message was authored by: She3
We keep getting a message and blank screen saying we should enter our sky viewing card. We have Sky Q so don't know if we're supposed to have a viewing card. Would someone help me please
Re: Keep getting message about entering our sky viewing card
Hi @She3
If you are a new customer then the Sky Q viewing card is normally posted to you before the installation by Sky Engineer.
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Hi @She3
Avatar for She3
Thank you for the information and it's worked
