Discussion topic: Just had Q installed so not used to it — how do I stop a recorded programme that I am watching.
Message posted on 07 Mar 2023 05:12 PM
I have just had Q installed so not used to it --- to watch a prog on catchup do I have to down load it and how do you do this
when watching a recorded or downloaded prog how do,I stop it before the end
the old remote had a little square that you pushed to stop the recording
thanks
Message posted on 07 Mar 2023 05:40 PM - last edited: 07 Mar 2023 05:48 PM
Re: Just had Q installed so not used to it — how do I stop a recorded programme that I am watching.
thanks
hi @Pensioner44
Welcome to SKy Q
To watch from catch up find the episode/programme you want to to watch & click on the thumbnail (it is likely to have an arrow pointing downwards in white showing in the thumbnail indicating 'download')
Once it has downloaded (or partially downloaded) it will show in your Recordings - Most Recent - Press the SKY Logo on the remote (it is a button) to quickly go to recordings
When you are watching a recording use the play /Pause ">II" button to pause the recording & then use the Back /Dismiss button ( 3 sided box with arrow pointing left) to exit it
Edit : Please note this Backup /Exit button action is a little inconsitent - it is mean to take you back one level (e.g. initially back to the recordings menu) but sometimes it exit completely back to live TV
Assuming you have the latest remote with a blue voice button on the front see this page for details on the buttons:
https://www.sky.com/help/articles/q-buttons-explained-voice
I suggest you have a watch of the variuous videos on your SKY box listed from the Home Page under the Help Tab
Edit 2 - You can also do a lot of things via Voice Control - the equivalent of the above is Voice command "pause" followed by Voice command "exit" (and "Exit" again as required)
For a full list of voice Commands see:
https://www.sky.com/help/articles/sky-q-voice-control-commands
