Discussion topic: Ive had no signal since last nite
This message was authored by: Denise12
No signal tried everything from turning it al of to going step hy step on yelly and sky even  you tube
Re: Ive had no signal since last nite
@Denise12  Is it a No Signal or No satellite signal?  The 2 are different issues.
Youtube on what? The TV or Sky box? Is there an error message?
Can the TV display anything? Freeview? Bluray? Apps?
@Denise12
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
