Discussion topic: Issues with SkyQ boxes and mini boxes
This message was authored by: Yaelllll
For months now I have been having issues with my SkyQ mini boxes either dropping their connection often, or saying that there is an issue with the connection (when there isn't).
Inhage very fast internet cabled into my house. Nothing we do fixes the issues, including switching off the boxes from the mains, rebooting the WiFi etc. ... nothing works.
I really need an engineer to come out and sort this, yet there seems to be no way to book this?!
Re: Issues with SkyQ boxes and mini boxes
Hi @Yaelllll
To book an Engineer you need to contact Sky directly.
Regarding your issue
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
This message was authored by: SEd
Is this a known issue as I'm having the same problem since changing to a new main box! I don't feel it's the option to keep having to reboot everything as it's a massive inconvenience, given how our TVs are set up. Why does it keep happening?
